After updating, I cannot open the web UI in many browsers; e.g., firefox and chrome on linux fc27, explorer on a windows phone.
It does work on my chrome on android.
On all browsers, I can open the /dev version of the url.
Greetings,
Arjen
Greetings,
Arjen
I have to correct this issue as solved
It was my own fault: I had forgotten that I had modified the HTML title in the index.html file at
/volumio/http/www/index.html
Apparently this causes trouble - replacing it by the old index.html (using git checkout) resolved my issues.
If you rewrite manually some volumio files, you will have for sure problems with OTA updates.
I suggest you to factory reset your volumio to avoid future troubles.
If you did overwrite your index.html for GA, take a look at this
github.com/volumio/Volumio2/tree/ga-opt-out
github.com/volumio/Volumio2-UI/tree/ga-opt-out
I am curious why you would do that!
