Hey guys,
i’m currently struggling with the consume mode. I always forget to disable it manually and mess up my playlists. Is it possible to automatically disable it at startup? Til now, I did not find a config file where I would be able to diasble this feature.
Help wil be much appreciated. Thanks in advance!
Greets
forget it, it will be turned on again by sth i don,t know
add the following lines to /etc/rc.local before exit 0:
(sleep 5;
mpc consume off
exit 0
and reboot
Hey weereew,
thanks for your reply. I already tried that with different sleep timers but had no luck either.
i think what control the consume mode should be a php script somewhere in /var/www
Yes, I thought so, too. I performed a grep for “consume” and similar search terms in this directory but did not find any results, which seem to do the trick.
sleep 5 is WAY too short. Try extending it to 30 or even 60 seconds. There may be more elegant ways, but I found the optimal delay this way:
- Put ( sleep 5; mpc consume off ) & in your /etc/rc.local
- Reboot Volumio (I’m on an RPi with I2S DAC)
- SSH into Volumio as soon as possible
- Type this into your terminal: while true; do mpc status; sleep 1; done
- When consume mode changes from OFF to ON, hit Ctrl-C
- Count the number of lines consume mode was OFF, and add at least that amount of time to “sleep 5” in your /etc/rc.local
- Test it!
With my RPi hooked up to an external monitor, I noticed that consume mode would revert to “on” the exact moment I received the following message:
pi@volumio:~$ [ 60.637074] bcm2835-cpufreq: switching to governor performance
That gave me an upper bound (60 seconds) for how long to set the sleep delay. I was able to reduce the delay to 28 seconds for my particular setup. YMMV. This is a known problem that will hopefully be fixed in future updates.
HTH - Adrian
