Hi all,
I built a nice case for my Volumio box and I have included some buttons on top for Presets. I created some single entry playlists and plan to map GPIO’s to run a command like:
curl “http://192.168.1.2/api/v1/commands/?cmd=playplaylist&name=Example” The REST API seems the easiest way to issue this basic command.
The command works just fine if I do it from any other linux box in the house, but when I run it from the volumio server via ssh, I get “connection refused”. If I can make this work from the command line, it will be a simple task to accomplish my preset goal. I’ve tried using the ip, loopback address, the host name, localhost…all get connection refused.
Any ideas to get this working?
Thanks!
