I want to upload music to Volumio over the network
But I could not find “\Volumio” or “\Music” (new player name) or “\198.162.1.13” (Volumio IP) in the network to access ramplay and other volumio folders
And I could not access Volumio by this addresses also
However I cold see “Music: root” and “Volumio” Media devices - I could not access to tear folders
And I could access to Volumio by web interface and MPD
I use volumio 1.5 for Cubox I
root@Music:~# sudo apt-get install samba
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following extra packages will be installed:
attr cron exim4 exim4-base exim4-config exim4-daemon-light guile-2.0-libs
libaio1 libfile-copy-recursive-perl libfribidi0 libgc1c2 libgsasl7
libhdb9-heimdal libkdc2-heimdal libkyotocabinet16 libmailutils4
libmysqlclient18 libntlm0 libunistring0 logrotate mailutils mailutils-common
mysql-common python-dnspython samba-dsdb-modules samba-vfs-modules tdb-tools
update-inetd
Suggested packages:
anacron checksecurity mail-reader eximon4 exim4-doc-html exim4-doc-info
spf-tools-perl swaks mailutils-mh mailutils-doc bind9 bind9utils ctdb
ldb-tools smbldap-tools winbind
Recommended packages:
mailx
The following NEW packages will be installed:
mysql-common python-dnspython samba samba-dsdb-modules samba-vfs-modules
tdb-tools update-inetd
0 upgraded, 29 newly installed, 0 to remove and 292 not upgraded.
Need to get 2395 kB/9741 kB of archives.
After this operation, 39.8 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
Err http://http.debian.net/debian/ jessie/main libunistring0 armhf 0.9.3-5.2
404 Not Found
Err http://http.debian.net/debian/ jessie/main exim4-config all 4.84-3
404 Not Found
Err http://http.debian.net/debian/ jessie/main exim4 all 4.84-3
404 Not Found
Err http://http.debian.net/debian/ jessie/main exim4-base armhf 4.84-3
404 Not Found
Err http://http.debian.net/debian/ jessie/main exim4-daemon-light armhf 4.84-3
404 Not Found
Failed to fetch http://http.debian.net/debian/pool/main/libu/libunistring/libunistring0_0.9.3-5.2_armhf.deb 404 Not Found
Failed to fetch http://http.debian.net/debian/pool/main/e/exim4/exim4-config_4.84-3_all.deb 404 Not Found
Failed to fetch http://http.debian.net/debian/pool/main/e/exim4/exim4-base_4.84-3_armhf.deb 404 Not Found
Failed to fetch http://http.debian.net/debian/pool/main/e/exim4/exim4-daemon-light_4.84-3_armhf.deb 404 Not Found
Failed to fetch http://http.debian.net/debian/pool/main/e/exim4/exim4_4.84-3_all.deb 404 Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
root@Music:~#
