I’ having thousands and thousands of these lines in the mpd.log rendering the log file almost useless.
Nov 12 06:40 : client: [5976] opened from 127.0.0.1:58799
Nov 12 06:40 : client: [5976] closed
There is a forum post in here about this but it does not solve the issue, it’s also a poor post because it describes two problems.
volumio-and-mpd-updating
When I do netstat -aon
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State Timer
tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN off (0.00/0/0)
tcp 0 0 0.0.0.0:49152 0.0.0.0:* LISTEN off (0.00/0/0)
tcp 0 0 0.0.0.0:6600 0.0.0.0:* LISTEN off (0.00/0/0)
tcp 0 0 0.0.0.0:8200 0.0.0.0:* LISTEN off (0.00/0/0)
tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN off (0.00/0/0)
tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN off (0.00/0/0)
tcp 0 0 0.0.0.0:5002 0.0.0.0:* LISTEN off (0.00/0/0)
tcp 0 0 127.0.0.1:9002 0.0.0.0:* LISTEN off (0.00/0/0)
tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN off (0.00/0/0)
tcp 0 0 0.0.0.0:56236 0.0.0.0:* LISTEN off (0.00/0/0)
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN off (0.00/0/0)
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN off (0.00/0/0)
tcp 0 0 0.0.0.0:81 0.0.0.0:* LISTEN off (0.00/0/0)
tcp 0 0 0.0.0.0:82 0.0.0.0:* LISTEN off (0.00/0/0)
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN off (0.00/0/0)
tcp 0 0 192.168.178.12:53556 192.168.178.14:445 ESTABLISHED off (0.00/0/0)
tcp 0 0 127.0.0.1:59066 127.0.0.1:6600 ESTABLISHED off (0.00/0/0)
tcp 0 0 127.0.0.1:56289 127.0.0.1:9000 TIME_WAIT timewait (52.80/0/0)
tcp 0 0 127.0.0.1:59074 127.0.0.1:6600 TIME_WAIT timewait (47.78/0/0)
tcp 0 0 127.0.0.1:6600 127.0.0.1:50838 ESTABLISHED keepalive (4234.20/0/0)
tcp 0 0 127.0.0.1:50826 127.0.0.1:6600 ESTABLISHED off (0.00/0/0)
tcp 0 0 127.0.0.1:59051 127.0.0.1:6600 TIME_WAIT timewait (27.59/0/0)
tcp 0 0 127.0.0.1:59081 127.0.0.1:6600 TIME_WAIT timewait (57.82/0/0)
tcp 0 0 127.0.0.1:59037 127.0.0.1:6600 TIME_WAIT timewait (7.48/0/0)
tcp 0 0 127.0.0.1:59049 127.0.0.1:6600 TIME_WAIT timewait (22.71/0/0)
tcp 0 0 127.0.0.1:56278 127.0.0.1:9000 ESTABLISHED off (0.00/0/0)
tcp 0 0 127.0.0.1:56251 127.0.0.1:9000 TIME_WAIT timewait (7.64/0/0)
tcp 0 0 127.0.0.1:50838 127.0.0.1:6600 ESTABLISHED off (0.00/0/0)
tcp 0 0 127.0.0.1:56265 127.0.0.1:9000 TIME_WAIT timewait (27.70/0/0)
tcp 0 0 192.168.178.12:42086 195.24.233.58:80 ESTABLISHED off (0.00/0/0)
tcp 1 1 192.168.178.12:54994 195.24.233.57:80 LAST_ACK on (13.52/6/0)
tcp 0 0 127.0.0.1:59046 127.0.0.1:6600 TIME_WAIT timewait (17.67/0/0)
tcp 0 0 127.0.0.1:56275 127.0.0.1:9000 TIME_WAIT timewait (42.75/0/0)
tcp 0 0 127.0.0.1:56293 127.0.0.1:9000 TIME_WAIT timewait (57.80/0/0)
tcp 0 0 127.0.0.1:6600 127.0.0.1:47154 ESTABLISHED keepalive (2227.14/0/0)
tcp 0 0 192.168.178.12:55212 195.24.233.57:80 ESTABLISHED off (0.00/0/0)
tcp 0 0 127.0.0.1:59053 127.0.0.1:6600 TIME_WAIT timewait (27.70/0/0)
tcp 0 0 127.0.0.1:59042 127.0.0.1:6600 TIME_WAIT timewait (12.66/0/0)
tcp 0 0 127.0.0.1:56272 127.0.0.1:9000 TIME_WAIT timewait (37.73/0/0)
tcp 0 0 127.0.0.1:59077 127.0.0.1:6600 TIME_WAIT timewait (52.78/0/0)
tcp 0 0 192.168.178.12:22 192.168.178.16:46986 ESTABLISHED keepalive (5422.02/0/0)
tcp 0 0 192.168.178.12:6600 192.168.178.16:60458 ESTABLISHED keepalive (4746.18/0/0)
tcp 0 0 127.0.0.1:59056 127.0.0.1:6600 TIME_WAIT timewait (32.72/0/0)
tcp 0 0 127.0.0.1:6600 127.0.0.1:59066 ESTABLISHED keepalive (7203.78/0/0)
tcp 0 0 127.0.0.1:56261 127.0.0.1:9000 TIME_WAIT timewait (22.69/0/0)
tcp 0 0 127.0.0.1:59044 127.0.0.1:6600 TIME_WAIT timewait (17.50/0/0)
tcp 0 0 127.0.0.1:59079 127.0.0.1:6600 TIME_WAIT timewait (57.70/0/0)
tcp 0 0 127.0.0.1:59039 127.0.0.1:6600 TIME_WAIT timewait (7.64/0/0)
tcp 0 0 127.0.0.1:56254 127.0.0.1:9000 TIME_WAIT timewait (12.66/0/0)
tcp 1 1 192.168.178.12:50827 195.24.232.208:80 LAST_ACK on (13.52/6/0)
tcp 0 0 127.0.0.1:59035 127.0.0.1:6600 TIME_WAIT timewait (2.63/0/0)
tcp 0 0 192.168.178.12:42089 195.24.233.58:80 ESTABLISHED off (0.00/0/0)
tcp 0 0 127.0.0.1:59060 127.0.0.1:6600 TIME_WAIT timewait (37.73/0/0)
tcp 1 1 192.168.178.12:37445 195.24.232.207:80 LAST_ACK on (13.49/6/0)
tcp 0 0 127.0.0.1:6600 127.0.0.1:58847 TIME_WAIT timewait (43.84/0/0)
tcp 0 0 127.0.0.1:56247 127.0.0.1:9000 TIME_WAIT timewait (2.60/0/0)
tcp 8 0 127.0.0.1:9000 127.0.0.1:56278 ESTABLISHED off (0.00/0/0)
tcp 0 0 127.0.0.1:56268 127.0.0.1:9000 TIME_WAIT timewait (32.69/0/0)
tcp 0 0 127.0.0.1:47154 127.0.0.1:6600 ESTABLISHED off (0.00/0/0)
tcp 0 0 192.168.178.12:80 192.168.178.16:42167 ESTABLISHED off (0.00/0/0)
tcp 1 1 192.168.178.12:41874 195.24.233.58:80 LAST_ACK on (12.21/6/0)
tcp 0 0 127.0.0.1:56258 127.0.0.1:9000 TIME_WAIT timewait (17.64/0/0)
tcp 0 0 127.0.0.1:56286 127.0.0.1:9000 TIME_WAIT timewait (47.73/0/0)
tcp 0 0 192.168.178.12:51045 195.24.232.208:80 ESTABLISHED off (0.00/0/0)
tcp 0 0 192.168.178.12:80 192.168.178.16:41980 ESTABLISHED off (0.00/0/0)
tcp 0 0 127.0.0.1:59072 127.0.0.1:6600 TIME_WAIT timewait (47.63/0/0)
tcp 0 0 127.0.0.1:6600 127.0.0.1:50826 ESTABLISHED keepalive (4234.15/0/0)
tcp 0 0 127.0.0.1:59063 127.0.0.1:6600 TIME_WAIT timewait (42.71/0/0)
tcp 0 0 127.0.0.1:56059 127.0.0.1:9000 TIME_WAIT timewait (43.85/0/0)
tcp6 0 0 :::445 :::* LISTEN off (0.00/0/0)
tcp6 0 0 :::60068 :::* LISTEN off (0.00/0/0)
tcp6 0 0 :::5002 :::* LISTEN off (0.00/0/0)
tcp6 0 0 :::139 :::* LISTEN off (0.00/0/0)
tcp6 0 0 :::111 :::* LISTEN off (0.00/0/0)
tcp6 0 0 :::22 :::* LISTEN off (0.00/0/0)
udp 0 0 127.0.0.1:932 0.0.0.0:* off (0.00/0/0)
udp 0 0 0.0.0.0:5353 0.0.0.0:* off (0.00/0/0)
udp 0 0 0.0.0.0:51443 0.0.0.0:* off (0.00/0/0)
udp 0 0 0.0.0.0:50972 0.0.0.0:* off (0.00/0/0)
udp 0 0 0.0.0.0:68 0.0.0.0:* off (0.00/0/0)
udp 0 0 127.0.0.1:57163 0.0.0.0:* off (0.00/0/0)
udp 0 0 192.168.178.12:55397 0.0.0.0:* off (0.00/0/0)
udp 0 0 0.0.0.0:1900 0.0.0.0:* off (0.00/0/0)
udp 0 0 0.0.0.0:111 0.0.0.0:* off (0.00/0/0)
udp 0 0 0.0.0.0:900 0.0.0.0:* off (0.00/0/0)
udp 0 0 192.168.178.255:137 0.0.0.0:* off (0.00/0/0)
udp 0 0 192.168.178.12:137 0.0.0.0:* off (0.00/0/0)
udp 0 0 0.0.0.0:137 0.0.0.0:* off (0.00/0/0)
udp 0 0 192.168.178.255:138 0.0.0.0:* off (0.00/0/0)
udp 0 0 192.168.178.12:138 0.0.0.0:* off (0.00/0/0)
udp 0 0 0.0.0.0:138 0.0.0.0:* off (0.00/0/0)
udp 0 0 0.0.0.0:49035 0.0.0.0:* off (0.00/0/0)
udp6 0 0 :::36539 :::* off (0.00/0/0)
udp6 0 0 :::5353 :::* off (0.00/0/0)
udp6 0 0 :::45811 :::* off (0.00/0/0)
udp6 0 0 :::36167 :::* off (0.00/0/0)
udp6 0 0 :::111 :::* off (0.00/0/0)
udp6 0 0 :::900 :::* off (0.00/0/0)
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags Type State I-Node Path
unix 2 [ ACC ] STREAM LISTENING 2347 /var/run/rpcbind.sock
unix 2 [ ACC ] STREAM LISTENING 2662 /var/run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 3179 /var/run/samba/winbindd/pipe
unix 2 [ ACC ] STREAM LISTENING 2711 /var/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 2973 /var/run/samba/nmbd/unexpected
unix 2 [ ACC ] STREAM LISTENING 3181 /var/lib/samba/winbindd_privileged/pipe
unix 3 [ ] STREAM CONNECTED 45386
unix 3 [ ] STREAM CONNECTED 2668
unix 3 [ ] STREAM CONNECTED 3182
unix 3 [ ] STREAM CONNECTED 96923
unix 3 [ ] STREAM CONNECTED 2443
unix 3 [ ] STREAM CONNECTED 3183
unix 3 [ ] STREAM CONNECTED 96924
unix 3 [ ] STREAM CONNECTED 3623 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 2896
unix 3 [ ] STREAM CONNECTED 2714 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 3622
unix 3 [ ] STREAM CONNECTED 2897
unix 3 [ ] STREAM CONNECTED 2713
unix 3 [ ] STREAM CONNECTED 3297
unix 3 [ ] STREAM CONNECTED 2667
unix 3 [ ] STREAM CONNECTED 3298
unix 3 [ ] STREAM CONNECTED 2707
unix 3 [ ] STREAM CONNECTED 45387 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 2706
unix 3 [ ] STREAM CONNECTED 2444
