Have done this numerous times before with good results but now when I flash the usb stick I only got 2 empty (unformated) disks
Have tried with Win32Diskimager and Etcher,
used x86 2.164 and 2.387 images,
on different usb sticks,
tried from 2 different computers
and the result is the same “2 empty (unformated) disks” !?
Just for fun I tried to flash a Pi image to the stick/sticks and that worked fine
Sounds odd. The last image is ok, because I have recently flashed it myself, so it comes down to hardware. I know that you’ve tried two, but if you’ve got another stick available Get a friend to flash it for you on their equipment? I’m sure that you can think of all these yourself; it’s one of those really annoying, niggly problems that waste so much time. Let us know how you get on, I’m really quite curious as to the cause
You can try this one for 2.344 updates.volumio.org/x86/volumio/ … 86.img.zip , but please note that I nothing about how stable this image is. If you know the exact image you want, then I can probably find it for you.
Thanks for the link
The result was the same with that image
But the problem is solved !
Correct me if i’m wrong , when flashing a x86 image to a Usb stick the disks/partitions are not visible in Windows (says that’s unformated) or ?
Checked a working stick in a Windows machine and it look/acted the same as my newly flashed , then I tried to boot on the newly flashed and it worked just fine
Yes, all Volumio disks result as a small readable partition and the rest of the disk is readable only by linux, so Windows sees it as unformatted space
