[SOLVED] can i install more than one volumio in a LAN
I am using volumio and everything run well.
can i install a second volumio in the same LAN?
best regards
Heinz
Yes, you can, but it is recommended to change the name of the first one.
thank you for your fast answer.
I already tried that ; i renamed the first volumio in volumio-1 . The second volumio i named volumio-2 and both ran together and i could open
them on a windows 10 pc in the browser. But no sound was to hear on either of the two. (Audio output was set to headjack) .
When i turned off one of the volumio`s the other one played the music.
best regards
Heinz
It should work ok. Can you specify in detail exactly what you tried and how please?
thx to all for the help. I detected an error in the headjack connection (the cable was broken) . After soldering now everything is running perfect.
best regards
Heinz
P.S.
How can i set this post to solved status?
