[SOLVED] Argon case + script
I put my rpi4 in the argon one case.
They give a script for debian based Os to manage power off, fan speed…
The steps are :
1/sudo wget download.argon40.com/argon1.sh
2/ sudo chmod 755 ./argon1.sh
3/ sudo ./argon1.sh
I try on other debian based os and it works fine.
But here on volumio i receive an error.
    volumio@volumio:~$ sudo ./argon1.sh
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    E: Unable to locate package raspi-gpio
    Please also connect device to the internet and restart installation.
    volumio@volumio:~$
Volumio is wired connected to internet (see screenshot below)
How could i deal with this ?
Thanks for helping.
You would need to install the missing package raspi-gpio, which is not part of the standard Raspbian repository.
P.S. Do so at your own risk.
This case is incredible !
I top to 40° after 2 hours of playing music on my PI4.
Here the guide to install the script
The installation steps :
1/ Connect SSH to volumio
2/ sudo apt update
3/ sudo apt install raspi.gpio
4/ sudo wget download.argon40.com/argon1.sh
5/ sudo chmod 755 ./argon1.sh
6/ sudo ./argon1.sh
Wait the script does the work and try to shutdown volumio using web interface
Then you will have a complete shutdown with power off.
Done !
How to use it :
To manage fan, go SSH use this command and follow the guide provide with the case
argonone-config
If you want to uninstall the hole script
argonone-uninstall
Thank you! I was looking for this!
Cheers!
-HK sends
Thanks to a491765 for a fantastic post! Efficient and effective! Thank you for saving others many hundreds of hours of research, trial and error!!!
Dear @a491765,
Thanks a lot for your valuable post. About me, I have just started to explore Argon M.2 Case and installed Volumio on the same. I know it is a too much to ask but can you please help me with the following —
  1. What all scripts or installations you made while installing Volumio on the Argon Case ?
Can you please guide me on the same before I start using the Argon case for Volumio.
Did you look at the manual provided with the Argon, page 12?
Thanks @Wheaten but will this be applicable to Volumio OS as this script is for Raspian OS.
yes it doesn’t matter.
The script will only install: raspi-gpio python3-rpi.gpio python3-smbus i2c-tools
(It will only not work together with Peppy_meter)
The only thing you MUST NEVER DO: sudo apt-get upgrade. This will break volumio.
Noted @Wheaten
Dear @Wheaten,
Just wanted to be double sure that I am not doing anything wrong. I am going to use a fresh installation of Volumio and Peppy meter using the Argon Case. Please help me with the below ----
  1. In order to ensure that I am able to run Volumio latest version with Peppy meter on Argon Case, which all commands below I should run and avoid ?
1/ curlhttps://download.argon40.com/argon1.sh
2/ sudo apt update
6/ sudo ./argon1.sh
  1. Finally the above commands should be run after Volumio & PeppyMeter is installed or before that ?
Kindly help…
Regards,
Rajiv
Not sure where you get these command from, but for sure interesting.
But I would suggest:
sudo apt-get update
curl https://download.argon40.com/argon1.sh | bash
Then install peppymeter.
Noted @Wheaten
