[solved] Arcam rPac
Hey folks,
My first post on the forums. Loving Volumio.
I have an Arcam rPac which I struggled to get working but eventually I managed it so I thought I’d share how to here.
It’s really simple once you know how. You have to launch it into USB 2 mode. Simple press both volume buttons when you power it on.
Then it’ll get picked up as A20 in the DAC selection box. If it comes up as A10 it’s in USB1 mode and may not play.
Also it didn’t work very well through a USB hub, I tried it without the hub and it works fine, the Pi can power it and a wifi dongle no problem.
joe
