[Solved] Any news about pulseaudio?
I’ve found this https://volumio.org/forum/pulseaudio-network-sink-t773.html discussion about pulseaudio support in volumio which is marked as solved but I’ve just downloaded and installed latest volumio image and I can not find pulseaudio support. Has it been implemented or has pulseaudio support been delayed?
Dragan
Even if it is maybe not exactly what you want, you can stream from pulseaudio (pc) to Volumio by using https://github.com/masmu/pulseaudio-dlna
It works perfectly! :smiley:
have look at this thread https://volumio.org/forum/streaming-from-ubuntu-and-other-linux-volumio-t2914.html (same thing than above).
I’ve the same question as I’ve not got to Raspberry Pi2’s with iQaudio DAC+ and would like to synchronise them and since MPD underlies Volumio it seems this looks pretty straightforward with PulseAudio.
I tried installing PulseAudio under the current Volumio install using ‘apt-get install pulseaudio’ but there are a number of packages missing from the repository…
# apt-get install pulseaudio Reading package lists... Done Building dependency tree Reading state information... Done The following extra packages will be installed: acl alsa-base cgmanager dmsetup ifupdown initscripts kmod libacl1 libasound2-plugins libaudit-common libaudit1 libavcodec56 libavresample2 libavutil54 libcap2-bin libcgmanager0 libcryptsetup4 libdevmapper1.02.1 libdrm2 libfftw3-single3 libkmod2 libmount1 liborc-0.4-0 libpam-cap libpam-systemd libpolkit-agent-1-0 libpolkit-backend-1-0 libpolkit-gobject-1-0 libpulse0 libpulsedsp libsmartcols1 libudev1 libvpx1 libwebrtc-audio-processing-0 libx264-142 mount plymouth policykit-1 pulseaudio-module-x11 pulseaudio-utils rtkit startpar systemd systemd-shim sysvinit-utils udev Suggested packages: ppp rdnssd libfftw3-bin libfftw3-dev desktop-base plymouth-themes pavumeter pavucontrol paman paprefs systemd-ui pm-utils bootlogd sash The following NEW packages will be installed: acl cgmanager libasound2-plugins libaudit-common libaudit1 libavcodec56 libavresample2 libavutil54 libcap2-bin libcgmanager0 libcryptsetup4 libdrm2 libfftw3-single3 libpam-cap libpam-systemd libpolkit-agent-1-0 libpolkit-backend-1-0 libpolkit-gobject-1-0 libpulsedsp libsmartcols1 libudev1 libwebrtc-audio-processing-0 libx264-142 policykit-1 pulseaudio pulseaudio-module-x11 pulseaudio-utils rtkit startpar systemd systemd-shim The following packages will be upgraded: alsa-base dmsetup ifupdown initscripts kmod libacl1 libdevmapper1.02.1 libkmod2 libmount1 liborc-0.4-0 libpulse0 libvpx1 mount plymouth sysvinit-utils udev 16 upgraded, 31 newly installed, 0 to remove and 444 not upgraded. Need to get 10.9 MB of archives. After this operation, 33.6 MB of additional disk space will be used. Do you want to continue [Y/n]? y Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main libmount1 armhf 2.25.2-6 [149 kB] Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main libsmartcols1 armhf 2.25.2-6 [103 kB] Get:3 http://mirrordirector.raspbian.org/raspbian/ jessie/main mount armhf 2.25.2-6 [164 kB] Get:4 http://mirrordirector.raspbian.org/raspbian/ jessie/main sysvinit-utils armhf 2.88dsf-59 [82.0 kB] Get:5 http://mirrordirector.raspbian.org/raspbian/ jessie/main startpar armhf 0.59-3 [20.5 kB] Get:6 http://mirrordirector.raspbian.org/raspbian/ jessie/main libacl1 armhf 2.2.52-2 [25.2 kB] Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libudev1 armhf 215-17 404 Not Found [IP: 5.153.225.207 80] Get:7 http://mirrordirector.raspbian.org/raspbian/ jessie/main libkmod2 armhf 18-3 [40.0 kB] Get:8 http://mirrordirector.raspbian.org/raspbian/ jessie/main alsa-base all 1.0.27+1 [54.3 kB] Get:9 http://mirrordirector.raspbian.org/raspbian/ jessie/main kmod armhf 18-3 [76.8 kB] Get:10 http://mirrordirector.raspbian.org/raspbian/ jessie/main libdrm2 armhf 2.4.58-2 [27.3 kB] Err http://mirrordirector.raspbian.org/raspbian/ jessie/main udev armhf 215-17 404 Not Found [IP: 5.153.225.207 80] Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavutil54 armhf 6:11.3-1+rpi1 404 Not Found [IP: 5.153.225.207 80] Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavresample2 armhf 6:11.3-1+rpi1 404 Not Found [IP: 5.153.225.207 80] Get:11 http://mirrordirector.raspbian.org/raspbian/ jessie/main plymouth armhf 0.9.0-9 [163 kB] Get:12 http://mirrordirector.raspbian.org/raspbian/ jessie/main libvpx1 armhf 1.3.0-3+rpi1 [352 kB] Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavcodec56 armhf 6:11.3-1+rpi1 404 Not Found [IP: 5.153.225.207 80] Get:13 http://mirrordirector.raspbian.org/raspbian/ jessie/main libx264-142 armhf 2:0.142.2431+gita5831aa-1+rpi1+b1 [495 kB] Get:14 http://mirrordirector.raspbian.org/raspbian/ jessie/main libpulse0 armhf 5.0-13 [221 kB] Get:15 http://mirrordirector.raspbian.org/raspbian/ jessie/main libasound2-plugins armhf 1.0.28-1+b1 [62.2 kB] Get:16 http://mirrordirector.raspbian.org/raspbian/ jessie/main libaudit-common all 1:2.4-1 [13.5 kB] Get:17 http://mirrordirector.raspbian.org/raspbian/ jessie/main libaudit1 armhf 1:2.4-1 [41.5 kB] Get:18 http://mirrordirector.raspbian.org/raspbian/ jessie/main dmsetup armhf 2:1.02.90-2.2 [66.6 kB] Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfftw3-single3 armhf 3.3.4-1+rpi1 404 Not Found [IP: 5.153.225.207 80] Get:19 http://mirrordirector.raspbian.org/raspbian/ jessie/main libdevmapper1.02.1 armhf 2:1.02.90-2.2 [138 kB] Get:20 http://mirrordirector.raspbian.org/raspbian/ jessie/main liborc-0.4-0 armhf 1:0.4.22-1 [116 kB] Get:21 http://mirrordirector.raspbian.org/raspbian/ jessie/main libcryptsetup4 armhf 2:1.6.6-5 [95.9 kB] Get:22 http://mirrordirector.raspbian.org/raspbian/ jessie/main ifupdown armhf 0.7.53.1 [62.9 kB] Get:23 http://mirrordirector.raspbian.org/raspbian/ jessie/main initscripts armhf 2.88dsf-59 [87.0 kB] Get:24 http://mirrordirector.raspbian.org/raspbian/ jessie/main acl armhf 2.2.52-2 [54.8 kB] Err http://mirrordirector.raspbian.org/raspbian/ jessie/main systemd armhf 215-17 404 Not Found [IP: 5.153.225.207 80] Get:25 http://mirrordirector.raspbian.org/raspbian/ jessie/main libcap2-bin armhf 1:2.24-8 [25.4 kB] Get:26 http://mirrordirector.raspbian.org/raspbian/ jessie/main libcgmanager0 armhf 0.33-2+deb8u2 [42.5 kB] Get:27 http://mirrordirector.raspbian.org/raspbian/ jessie/main cgmanager armhf 0.33-2+deb8u2 [71.7 kB] Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libpam-systemd armhf 215-17 404 Not Found [IP: 5.153.225.207 80] Get:28 http://mirrordirector.raspbian.org/raspbian/ jessie/main systemd-shim armhf 9-1 [16.1 kB] Get:29 http://mirrordirector.raspbian.org/raspbian/ jessie/main libpolkit-gobject-1-0 armhf 0.105-8 [35.4 kB] Get:30 http://mirrordirector.raspbian.org/raspbian/ jessie/main libpolkit-agent-1-0 armhf 0.105-8 [19.9 kB] Get:31 http://mirrordirector.raspbian.org/raspbian/ jessie/main libpolkit-backend-1-0 armhf 0.105-8 [37.8 kB] Get:32 http://mirrordirector.raspbian.org/raspbian/ jessie/main libpulsedsp armhf 5.0-13 [36.4 kB] Get:33 http://mirrordirector.raspbian.org/raspbian/ jessie/main libwebrtc-audio-processing-0 armhf 0.1-3 [81.6 kB] Get:34 http://mirrordirector.raspbian.org/raspbian/ jessie/main libpam-cap armhf 1:2.24-8 [12.1 kB] Get:35 http://mirrordirector.raspbian.org/raspbian/ jessie/main policykit-1 armhf 0.105-8 [57.1 kB] Get:36 http://mirrordirector.raspbian.org/raspbian/ jessie/main pulseaudio-utils armhf 5.0-13 [67.5 kB] Get:37 http://mirrordirector.raspbian.org/raspbian/ jessie/main pulseaudio armhf 5.0-13 [892 kB] Get:38 http://mirrordirector.raspbian.org/raspbian/ jessie/main rtkit armhf 0.11-2 [27.9 kB] Get:39 http://mirrordirector.raspbian.org/raspbian/ jessie/main pulseaudio-module-x11 armhf 5.0-13 [31.7 kB] Fetched 4,166 kB in 5s (729 kB/s) Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/systemd/libudev1_215-17_armhf.deb 404 Not Found [IP: 5.153.225.207 80] Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/systemd/udev_215-17_armhf.deb 404 Not Found [IP: 5.153.225.207 80] Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libav/libavutil54_11.3-1+rpi1_armhf.deb 404 Not Found [IP: 5.153.225.207 80] Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libav/libavresample2_11.3-1+rpi1_armhf.deb 404 Not Found [IP: 5.153.225.207 80] Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libav/libavcodec56_11.3-1+rpi1_armhf.deb 404 Not Found [IP: 5.153.225.207 80] Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/fftw3/libfftw3-single3_3.3.4-1+rpi1_armhf.deb 404 Not Found [IP: 5.153.225.207 80] Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/systemd/systemd_215-17_armhf.deb 404 Not Found [IP: 5.153.225.207 80] Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/systemd/libpam-systemd_215-17_armhf.deb 404 Not Found [IP: 5.153.225.207 80] E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
The suggested ‘–fix-missing’ flag doesn’t solve the problem either and I’m wary up updating the whole install.
Aside from SoundCloud integration this is the other final step I’m keen to resolve. This thread too has been marked as ‘[SOLVED]’ but I can’t see any solution. Does this mean that the issue has been solved in the development version on Github and will be included in a future release?
