[Solved] andypi lcd mpdlcd.conf permission denied rasp pi
Having a problem getting my andypi 16x2 hd44780 lcd working with volumio 1.55 on raspberry pi B.
keep getting
pi@volumio:~$ wget -O /etc/mpdlcd.conf raw.github.com/rbarrois/mpdlcd/ … pdlcd.conf
/etc/mpdlcd.conf: Permission denied
any help is much appreciated
thanks
you should sudo to the root user before executing this command:
sudo su -
or execute using sudo.
