Unfortunatly Volumio no longer seems to use the init.d script but starts shairport in the /var/www/command/player_wrk.php script:
I changed the name to VolumioAir and changed the device “hw” construction (to -d default:M2496) in order to get my Musical Fidility V90 usb dac to work without generating a lot of noise:
// Start Shairport with Volumio name, stopping Mpd on start, with Selected output device
$cmd = '/usr/local/bin/shairport -a "VolumioAir" -w -B "mpc stop" -o alsa -- -d default:M2496 > /dev/null 2>&1 &';
Changing the code and rebooting worked for me (toggling the airplay option in the webinterface didn’t)
Thanks, that worked a treat with airplay. However when i use Linn Kinsky or another upnp client it still says Volumio as the name. Any idea which script it is using for that ?
In case of upnp volumio seems to use the init.d script /etc/init.d/upmpdcli, this reads the configuration file /etc/upmpdcli.conf
In this conf file you can define the UPNP "friendly"name:
# Displayed "Friendly Name" for the UPnP Media Renderer
friendlyname = VolumioUpnp
Losing the ability to change the Airplay name is a real drawback. I’m running 3 x Volumio with IQaudio DAC in my house and now cannot upgrade past V1.3 because of this. The fix described above doesn’t work for me.
Can the feature be re-introduced please? V1.4 is a real improvement, particularly stability and the Library view on the web GUI is excellent.
