[SOLVED] 2.201 -SSH Disabled by default - how to enable ?
hi all,
i’m surely missing some point but on this version (2.201) i can’t login with SSH.
According to changelog “SSH Disabled by default (can be enabled via file or UI)”
but i can’t found a menu in UI …
some tips ?
regards,
Marc
volumio.github.io/docs/User_Manual/SSH.html
SSH access on volumio
For security reasons, SSH is disabled by default on all versions after 2.199 (except first boot). It can be however enabled very easily.
First method: file
Just create or copy a file called ssh in /boot . You can do it right after flashing Volumio, by creting it in the “Boot” partition of your SD Card.
Second method: DEV UI
Navigate to the DEV ui by pointing your browser to VOLUMIOIP/DEV or volumio.local/DEV . Find the SSH section, and click enable. From now on your SSH will be permanently enabled.
thanks it works (dev page method) !
merci beaucoup
