Volume control has lag on Volumio 3.
The Volumio OS is installed on Raspberry Pi 4 with 4 GB of RAM and SanDisk Extreme SD card.
I don’t think the hardware should be an issue and neither the network connection.
Same issue is present on Wi-Fi / Ethernet or direct remote control via IR Remote Controller.
Only volume control has lag, play/pause works far better.
MPD control is off, but i can still control volume directly from Spotify.
Any ideas?
