So Far No Issues But One Concern
My installation of Volumio 3.703 was fast and easy. I have had the program on my Pi 4 installed for about a week. It’s been rock solid. I read a few posts of Volumio dropping the WiFi configuration. I have not had that problem. I used my ethernet cable for the setup only. My concern is that I cannot keep my ethernet cable connected because of the long distance. I connect by WiFi only. Are there any issues with the WiFi reliability with Volumio 3.703?
