First of all thanks for your amazing work regarding this awesome plugin!
As a background I had a running setup with manual installed snapcast server and client V0.11 and librespot. Currently I am facing the problem that I cannot get an output via the Spotify “stream” with VolSpotConnect2 nor librespot (standalone).
My volumio version is 2.201 and I have installed your plugin (server and client v0.13 and then the volspotplugin2).
The volspotplugin is working in standalone (I can connect with Spotify and play music).
I have manually changed to pipe and /tmp/spotififo but after every restart it goes back to alsa and plughw:1.
What is the exact settings of volumio and your plugin to get all that working?
When i play internet radio this only works after a restart later there appear mpd problems.
How can i solve that?
My goal is to get volumio/Spotify/Airplay (Shairport sync running with snapcast.
Where is my failure?
Hope you can help me to get it running again.
Thank you in advance.
