Hey guys, I tried many time the sleep function but it doesn’t work. Nothing happens. In addition, if i choose 9.20 P.M the system will save 9.19 P.M. It always reduces by one minute.
How can i fix this problem ? Thank you.
Firstly what version of Volumio are you using and on what platform?
Hi, i’m using Volumio 2.201 on Raspberry pi 3
Well it does work here, but not exactly how it should do … yes the time to sleep shown is less one minute, and it didn’t seem to shut off at the correct time. Would you please raise an issue on Github please github.com/volumio/Volumio2/issues
i did it
