Does anyone know if there is a way to stream Sirius XM through Volumio?
+1 - would love to see this feature
+1
I would also like to see a plugin for SiriusXM.
I currently have to use another device to play Sirius when I’m in the mood for Full Serve over Self Serve.
What device do you use? Thanks
Amazon echo.
+1 - would love to see this feature also.
Yet another user who would love this feature. Raspberry Pi 4.
I have Youtube Music, which mostly works… have to uninstall/re-install from time to time, but it’s ok.
I have XMRadio accounts for our vehicles, have to pay it anyway, it’d be nice to be able to use it on my Volumio distributed music system.
Has anyone been able to build the siriusxm app into a plugin?
Have there been updates on adding SiriusXM to Volumio?
I don’t have the skills to make a plugin, but if you’ve got another machine handy on your network, you can run a proxy that can serve streams to your Volumio instance.
I made some slight changes to andrew0’s proxy code that will let yo do this as of August 2024. I’m running this on FreeBSD, but I would think it’ll run on any POSIX box with Python 3.x.
I think that it would be possible to convert this to a plugin, I’m just not a Javascript/frontend guy. It’s a really simple server that pretends to be a SiriusXM user in a web browser and creates and forwards an HLS stream. I think it would just need some UI for getting the user’s credentials and authenticating with SXM.
Also, I haven’t been able to figure out where the text that displays on a SiriusXM receiver comes from. It would be nice for a plugin to be able to grab that text to display in Volumio.
Even if I understand your expectations, most plugin are developed by the community…
So if someone motivated see your post… ![]()
That’s what I’m thinking. I’m not a Javascript guy, so I can’t do it myself, but I really feel like the core functionality from this script could be the guts of a plugin.
I’m really interested in setting this up. Can you give me a view instructions on what I need to do to setup? many thanks
what tweaks did you have to make? I want to try this!
have look here : https://developers.volumio.com/
I’m not at the plugin stage .haha I’m just trying to reproduce what dw808303 did. He mentioned tweaks he needed to do. What are they?
I was able to run this python script on another rpi3 that I have to “plugin” to fire it up. Once I do that, I can get any siriusxm channel thru volumio web radio. Anyone who has a siriusxm subscription… this is a game changer!!!
Great news, jocoman! I’m sitting here right now listening to SiriusXMFC on my kitchen radio (which is a Raspberry Pi 3 plugged into an old laptop speaker) — I probably use this hack daily.
dw808303. I use it daily as well, and the siriusxm stream quality is much better than I thought it would be. Thanks for posting, i would never have discovered this otherwise.
