Simple eq disables i2s, ¿and lowers quality?
Hi all
Im running volumio in a r4 with allo digione hat, audio out via coax to powered speakers
When you enable de simple eq, it disables the is2 setting in the playback configuration and routes the audio to the plugin
Is is safe to asume that this process lowers de quality of the audio by not using the i2s protocol?
Is there an audio quality tradeoff for using the eq plugin?
This is just a display problem. The Dac still use I2c or it would not work…
