Silence Detector
Hi
i´m using Volumio since a few years. It works nearly flawless. Only one little problem: the player stops randomly and i have to press play again.
Before i had Wimamp it used a plugin called “Silence Detection”, after 5 seconds silence ist started for example the next playlist entry.
Is there a chance to get this feature in Volumio`
winampplugins.co.uk/silencedetector.html
I think it would be better to figure out why the player stops randomly instead of trying to treat the symptom :wink:
Look into your logs to check if there is something suspicious going on?
Pretty simple. The streams are Stopped by the Radio Station…
