Hi to all,
Is there (or can it be made) a pin on the 40-pin header which will be high when music/signal is played and goes low when music/signal is stopped?
Audiophilelistener
Hi to all,
Audiophilelistener
Have you looked at the Amplifier Switch plugin? It should be available from the Volumio plugin page
