tobbes
December 18, 2013, 7:17pm
1
I just downloaded volumio for Pi and tested it.
The LCD is running as AndyPi explain on his homepage.
But my problem:
Volumio always reboots when I try to shutdown …
This happens over ssh “sudo shutdown now”, same with the web GUI and also over a GPIO that sends sudo shutdown now.
How can I fix it?
Yours Tobbes
volumio
December 18, 2013, 11:24pm
2
Kernel issue… Nothing to do except changing kernel
tobbes
December 19, 2013, 4:53pm
3
Thanks for your answer.
Is ist a known issue with this release or I am the only one with this bug?
Should it help to install volumio again on sd card?
Tobbes
FranzG
December 19, 2013, 5:05pm
5
Yes, I have the same behaviour: shutdown is resulting in a reboot. I am using a Raspberry Pi
Franz
tobbes
December 19, 2013, 5:08pm
6
@Karsten
Yes is just the same with this command. The pi restarts immediately.
So I think a new copy on sd card will not be the solution.
Is there a fix for the kernel possible for a newbie?
Tobbes
No, just wait for the next release. I’m planning it really soon!
iorr
December 19, 2013, 6:00pm
8
It works here !
Maybe because of this … sudo apt-get update && apt-get dist-upgrade
Karsten
tobbes
December 19, 2013, 8:34pm
9
It is a good idea to do a apt-get upgrade (not a dist-upgrade) with volumio?
With raspyfi it was good way to lose your system.
What do the experts think?
Tobbes
iorr
December 19, 2013, 10:22pm
10
don’t ask. Do it and it works …point.
With raspyfi ‘rpi-update’ was not so good because of the kernel update.
Karsten
tobbes
December 20, 2013, 9:18pm
11
Hello Karsten,
Thanks for your tip. sudo apt-get update && apt-get upgrade did fix the shutdown problem.
The Web GUI is stil running.
Great!
Tobbes
Unfortunately I had a different experience. I tried the update and dist-upgrade and ended up with an RPi that kept rebooting after being active for around a minute or so. Would boot up, get the web GUI but then it would die and reboot.
Reflashed with the beta and all is well again (apart from the reboot on shutdown).
So not I just SSH in and:
sudo shutdown -h -H now
M.
tobbes
December 23, 2013, 10:01am
14
Maybe do a apt-get upgrade (not a dist -upgrade)
hope that helps …
Tobbes
volumio
December 23, 2013, 12:33pm
15
Do you have an idea of the specific package to be upgraded? Doing a complete upgrade can mess the configuration…
tobbes
December 25, 2013, 8:40pm
16
Okay I do not know in detail.
Think it was a lot about bootmanager printed in the shell.
Tobbes
volumio
December 26, 2013, 3:47pm
17
New bugfix version solves this!
