I’m looking for a way to retrieve&display the current bitrate/resolution in use by volumio/mpd while playing…
Any suggestions??
Any suggestions??
Not 100% sure (not able to verify right now) but if I call correctly you have to look into /proc/asound/card0/pcm0p/sub0/hw_param something. There you can find the actual bitrate while playing.
Sent from my iPhone using Tapatalk
Card 1 actualy for me since i use both a DAC for volumio/2.0 sound as the HDMI sound for kodi with 5.1
access: RW_INTERLEAVED
format: S16_LE
subformat: STD
channels: 2
rate: 44100 (44100/1)
period_size: 2048
buffer_size: 16384
Thanx for the tip !!
