I am trying to mount a shared NFS folder from my FreeNAS server but Volumio keeps timing out, trying to mount this share. The fields seem to be straightforward but is there someway of putting in the path name, for example. The folder has its permissions set to read and write.
you can put a pathname but you have to leave off the lead /
so /Share/Music should be Share/Music
you might even want to shorten your share so its just server/share
which becomes
Server
Music (Share)
Thanks for that. I will give that a shot.
