This is a community forum, for support specifically with myVolumio, email techsupport at volumio dot org!
Hi, I have a RaspBerry 3b+ which has been working fine for years but after a failed SD I had to create a new installation.
the problem is that when I try to stream using Shairport, the volume is too low on my receiver, If I ply a file directly or Spotify or Pandora or via UPNP it sounds normall (GOOD) but when using airplay the sound is very low.
This was not heppening before, therefore I really appreciate your help.
CHeers
