I have questions about shairport. I want to use it for streaming appleTV to Volumio. It works but with a lot of delay. How I can I rit off the delay? When you start streaming it stutters also a lot but goes away after a view seconds.
Is shairport is the same as airplay and it works with you’re network? I have everything wired. Accept my iphone, then also stuttering.
The delay is around 4 seconds. I tried to edit /etc/shairport-sync.conf but seems to have no effect.
I like to use the dsp for improve the bass sound. But also like to stream AppleTV to Volumio. I did increase the buffer to 0.25 and then no stuttering. But till now I can not find the good latency value for it.
Do I have to make a choice between dsp or no dsp?
on the alpha the buffering was even worse. Do I get the beta bookworm from 192.x.x.x/dev enable testmode? Or do I have to install alpha and than update?
I think the buffering is because of the limited ram on rpi3(1gb) It is also on bluetooth (4.2 bluetooth I think) with a lot of out of lipsync. When I stream from Appletv to my active speaker with bluetooth no problems no delay no buffering.
On the rpi5 is bluetooth 5.0 that could be an improvement. Than I have to find using bluetooth or airplay to raspberry (Volumio). With the rpi3 I stop trying. Specs of that board are not good enough for Volumio. Only standard use.
thanks for all the support and information so far.
On the Alpha editing shairport-sync.conf.tmpl has no influence. Very worse stuttring on the Alpha. I.can not use shairport with dsp.Solution buying a equalizer. Thinking about the Schiit Loki 6 band
