I have a Raspi2 which is connected to my Denon 1713 using a HDMI cable and everything is fine running with RuneAudio.
Now I wanted to try Volumio and installed it with Etcher under Xubuntu 16.04. The Raspi boots up and I can enter its settings, update it and install the Spotify Plugin.
My problems are the following:
I can access my Spotify playlists and choose some music, it starts playing but I can’t hear anything (mixer is set to NONE, volume is at 40%).
I added a music folder from my NAS using cifs (it is a SAMBA share with user and loggin). It is successfully mounted (ca. 1 TB) but I can’t find my music.
I can’t switch to German language. I can choose German but Volumio jumps back to English.
I really would like to use Volumio, it’s looks imo more promising than RuneAudio which seems to be dead so I hope someone can help me solving my issues.
Ok, I test-added another drive (H67A:Öffentlich) on another machine (running Xubuntu) and everything is fine: Its music (I copied from my NAS) is found within a few seconds.
Well, almost everything: It is shown as NOT mounted and can’t be removed now whereas my actual NAS (running Openmediavault) is shown as mounted but its music can’t be found (user and password are correct, I just crosschecked this):
