Currently you select a track from your library and it will play immediately.
If you want to add it to the queue you have to do this from the context menu. On a mobile device this is a real hit and miss experiance.
This is completely backwards for me, the majorty of the time I am wanting to “add to the queue” so for me it should be the default action and if you want to play immediately use the context menu and play.
I am sure there are others who prefer select to play immediately as the default action.
So can we please have an option so that you can choose what the default select action is…
either… “play immediately” or "add to queue"
