Seems you have a power supply issue as no image seems to work. Are yu able to exchange the power supply?
You wrote that you are new to Raspberry Pi; are you sure that the SD card is inserted properly? You should be able to push it in the slot until you feel it locks. That way you also have the check that it sits the right way up.
SD card is inserted properly. I now have a video monitor for it, but i don’t get anything at the monitor. I have tried both monitor outputs and the monitor says no signal in both cases. I also got an old PC working again and reformatted the card for FAT32. Same results. Solid red light from the moment i turn it on.
Could this be a defective R-pie4?
Defective rPi or defective PSU.
Either way, they are getting returned. Thank You everyone for all the guidance. Hopefully the next Raspberry Pi will work.
