I would like to use pandora unfortunately i’am bases out of the us.
Could you add the VPN fonctionality ? Or explain to me how can we setup a VPN on Volumio
Regards
Regards
Adding VPN functionality directly to Volumio is not currently possible, there are several ways to access Pandora outside the US using a Volumio and a VPN. Such as:
Use a Raspberry Pi with Volumio and a separate VPN app. Install and configure Volumio into your Raspberry Pi as usual. Choose a reputable VPN app compatible with the Raspberry Pi platform such as as ExpressVPN and PureVPN. Follow their app’s installation and configuration instructions. Then start the VPN app and connect to a server in the US.
Another option is to configure your router to connect to a VPN service and route all internet traffic through the VPN tunnel. Ensure your Raspberry Pi connected to Volumio uses the VPN router’s WiFi network or ethernet connection.
Using any of these options should allow you to access Pandora on your Volumio system even if you’re outside the US.
