Interface issue: When selecting tracks to add to a playlist, the multiple choice window is now getting stuck on, making choosing the next track difficult.
This window used to fade away after clicking a choice, but now it requires a second click somewhere else to get it to go away, making it difficult to select the next track for instance. There aren’t a lot of places to click that don’t produce unwanted results.
Prerequisites
Volumio Information
Volumio Version: 2.834
Hardware: Raspberry Pi 3
DAC: HIFiBerry Digi+ Pro
Debug Log
http://logs.volumio.org/volumio/L3yxVff.htmlSteps to Reproduce
- in volumio interface, select music library, then USB or whatever gives a file list
- Select a track, then click at the right end, the pop up shows up - select add to qeue, window should fade out after the selection is made, but doesn't
