select webradio track
Hello.
Thanks for the great software, been using it for years.
My favorite radio station publishes EXTM3U playlist, which has 3 tracks and the last/third one is with best quality/bandwidth. I can select it manually (pressing next track twice on UI). Is there any trick, how to select the third/last track by default?
The tracks’ URL address keep changing, so I can’t use them statically.
Thanks in advance.
Don’t think so. If you consider it worthwhile then raise it as an issue on the Github site github.com/volumio/Volumio2/issues
