See MAC address via Volumio web interface?
Hi all,
I have several Odroid C2 running Volumio. I would like to attribute a fixed IP address on my LAN and for that I need to know the MAC Address of the device. The Odroid is buried in a place where it is hard to get at and the modem/router of my provider does not have a function to show the MAC addresses of all the devices connected.
Is there any way to see the MAC address from the Volumio Web Interface? The IP address is there under the network tab, but not the MAC.
Thanks a lot
I think no. But there is more ways how to get MAC address. You can connect to volumo via SSH (volumio.github.io/docs/User_Manual/SSH.html) and run linux command (ifconfig) or you can open the web config of your router and look in connected devices.
Or on a Android device, install Fing. You’ll see all your device by ip and Mac.
