Search from Playlist tab?
Are there any plans to enable the search function in the Volumio Playlist Tab? The search bar is there and lets you type in a Band, ex: Eagles, but when you do the search, it reveals nothing. The super search works but that is not the goal. See pics below:
What can be done to fix? or add this feature.
Hi!
I tested and it works for me… What is your device and version of volumio?
@balbuze Thanks for responding. Here is my system info. I am up to date. And while I have the pi5 ths feature did not work with the pi 4 either.
i Note it does work if I am in Qobuz playlists.
Here is the Player State when I try to search
