Hi all,
Wanna share an issue, but solved so that everyone get a little bit happier with volumio.
I have latest stable volumio version on a pi3 using a compatible dac, and love it, until I get it restarted or turned off.
I take off the sd card and put it on my windows laptop do usb check and is back online.
But the latest time I hot this issue that instructions didn’t solve, I was only able to revive the sdcard doing a e2fsck on gparted live ISO on the sda volumes of the sdcard.
So my instructions when sdcard don’t boot is to do a Windows check on the fat boot partition or do a e2fsck using a live Linux distro.
check if that helps
