SD card speed
Hello all
assuming NOT to use Raspberry’s boot SD card for music storage but just for the system, is there a big advantage in using a Class 10 SD card, or an ordinary class 4 will do?
Also: how big should it be?
Or better asked: how small can it be? :slight_smile:
Thanks in advance for help
ciao
Alberto
Hello Alberto,
Volumio runs from RAM so the speed of the SD card has no influence to the running system. A slower card just could extend the boot time a bit and will take more time to flash it.
According to the card size have a look here : https://volumio.org/forum/what-the-minimum-size-micro-card-for-volumio-t5259.html
Cheers
Pirx
All clear! Thanks!
