Hi all,
Quick fix for screen resolution if you would like to change it on a PC based install. Would be nice to have the as a feature of the UI in a future release.
SSH into your box (you may need to enable ssh, see the documentation for that).
Edit /opt/volumiokiosk.sh
sudo edit /opt/volumiokiosk.sh
Add the following to the while true set in order to set the X screen resolution and then the resolution that chromium displays at.
To set screen res:
xrandr -display :0.0 --output VGA1 --mode "1440x900"
And to set chromium add this to the chromium command line:
--window-size=1440,900
Your new script should look like:
[code]#!/bin/bash
xset -dpms
xset s off
openbox-session &
while true; do
rm -rf ~/.{config,cache}/chromium/
xrandr -display :0.0 --output VGA1 --mode “1440x900”
/usr/bin/chromium --disable-session-crashed-bubble --disable-infobars --kiosk --no-first-run --window-size=1440,900 ‘http://localhost:3000’
done[/code]
Of course set the resolution to something that your screen can display.
Reboot your system.
Enjoy
-Saff
