risking a ‘RTFM’, on CON5 there’s missing SCK…
Where can I find it? The T_DAC seems to have it from somewhere else, but I haven’t figured out from where.
Sarah
Hi Sarah you deserve a reply for the way you asked ! Even if it was a bit cryptic…
Are you meaning P5 on PI and clock? If yes, PI cannot provide a clock to the DAC… Gotta use an external oscillator…
If I misunderstand just explain a little bit more…
Hi Michelangelo,
unfortunately You got me correct…
Sorry when I was a bit cryptic but the deeper You go into an issue the less is the ability to speak to ‘normal’ perople
Well then I have to see if it works, with another clock source.
I just looked again at the Rpi-DAC layout and tried to follow the SCK trace. Does it end at the pins 8 and 10 of P1? It’s GPIOs and Rx/Tx …
I’m a bit confused.
Sarah
