scanning of large network share fails
I have 2 network shares with mostly flacs in it. One is a small, temporary share, another one is a large one. When I try to set up, it scans the small one easy, but if I start the large one, it scans for several hours and it fails. I do not know what is the error. I started a scan last evening and this morning the RPI3 was shut down. When I rebooted, the large folder is not there. Like I was not connecting at all. It does appear at the setup screen, both folders, but when I try to browse, I do not see it at all.
Is there a logfile or something I can get closer to find what is the problem?
Another player on an RPI 2 scans it fine. It takes about 12 hours, but it works.
What is the largest library what Volumio can handle?
Thanks a lot,
JG
Have a look at the journal log (sudo journalctl)?
I can not say I understand it all :frowning:
These are highlighted, but I do not know where to go with it :
#May 31 05:18:08 konyha kernel: CIFS VFS: ioctl error in smb2_get_dfs_refer rc=-2
There are hilighted ones from about the boot time, but it was scanning at about 21:00 and these came before :
#May 30 20:30:12 konyha winbindd[861]: [2019/05/30 20:30:12.133153, 0] …/lib/util/debug.c:603(reopen_logs_internal)
#May 30 20:30:12 konyha winbindd[861]: Unable to open new log file ‘/var/log/samba/log.winbindd-idmap’: No such file or directory
#May 30 20:30:12 konyha winbindd[862]: [2019/05/30 20:30:12.162250, 0] …/lib/util/debug.c:603(reopen_logs_internal)
#May 30 20:30:12 konyha winbindd[862]: Unable to open new log file ‘/var/log/samba/log.wb-BUILTIN’: No such file or directory
#May 30 20:30:12 konyha smbd[858]: [2019/05/30 20:30:12.210784, 0] …/lib/util/become_daemon.c:124(daemon_ready)
#May 30 20:30:12 konyha smbd[858]: STATUS=daemon ‘smbd’ finished starting up and ready to serve connections
#May 30 20:30:12 konyha smbd[863]: [2019/05/30 20:30:12.214248, 0] …/lib/util/debug.c:603(reopen_logs_internal)
#May 30 20:30:12 konyha smbd[863]: Unable to open new log file ‘/var/log/samba/log.smbd’: No such file or directory
I have uploaded here, if you may have a look : mega.nz/#!8oQDCIhY!-xfSQHXHwJZp … XWxWmr3T-g
Thanks a lot!
JG
I have tried to make a new scan, checked this morning. What I find in the journal file, it starts with a booting now at 6:03.
Now I have the scanned drive, I can browse it, but it in incomplete. :frowning:
JG
