Still beating my way through static ip address change.
If I do this:
change Wired Lan to “Automatic IP OFF”, and then add my “Static IP to 192.168.1.212”, “Save”, I lose my etho0 settings, and can no longer communicate with the RPI.
Using the keyboard and local monitor, if I do “ifconfig”, I get:
eth0 Link cncap:Ethernet HWaddr b8:27:eb:dd:b1:bf
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:4062 errors:0 dropped:0 overruns:0 frame:0
TX packets:1962 errors:0 dropped:0 overruns:0 carrier:0
collisions: 0 txqueuelen:1000
RX bytes:203319 (198.5 KiB) TX bytes:203319 (198.5 KiB)
So, no IP address at all.
Now, if I do:
"ifconfig eth0 192.168.1.212 netmask 255.255.255.0 up
then do:
“if config”, I get:
eth0 inet addr:192.168.1.212 Bcast:192.168.1.255 Mask:255.255.255.0
But when I reboot, all of this is gone, and I have to go through all of it again.
It appears the ‘Save’ function for Wired and Wireless is not functioning correctly.
Any help would be appreciated!
