Hello , I recently purchased a transport i2c hifiberry Digi for raspberry B.My setup consists of raspberry (obviously ) Digi , and Musical Fidelity V - DAC , Volumio , usb key , ub with 4 usb powered .It works well , just one problem , will not play files with sample rates above 16 -bit 44 .1khz .Using mostly FLAC but beyond 44 .1khz just feels fast pop higher you climb with frequency.Someone can help me ?thanks
Andrea,
What version of volumio are you using ?
Kevin
Version 1.5
Andrea, Upgrade to 1.51 or go back to 1.4, see below:-
Ohhh thanks …
But the version 1 .51 I have not found on the site.
No excuse …
The version I use is 1 .51 , and gives me this problem .
I try to install the 1 .41
I did some tests
With version 1 .51 and 1 .41 does not work
Don’t have a HiFiBerry Digi to test but I have been posting on this topic
http://volumio.org/forum/always-pcm-signal-dac-t2159-10.html
Common factor is the Digi. Have a look at the tests that were done and maybe you can try one or 2.
We need someone who has had success with HiFiberry Digi to post !
Still I can not explain how, but , I removed the version 1 .41 put the 1 .51 and now works up to full resolution .
I do not know what was wrong before …
Thanks for the support
