Sainsmart Dac
Some how I goofed and bought the wrong board.
I’m using an RP3
This is the board
sainsmart.com/products/hi-f … pi-model-b
It uses PCM5102A chip.
Which Dac board in the list could I use? I tried Generic and a couple others. No sound.
Hi thetazzbot,
This DAC works with the “HiFiBerry DAC” setting.
It doesn’t have hardware volume control. So set the mixer to “None” or “Software”.
  • Josef
Thanks, that did the trick. But I had to reboot the rpi. Even though the system says “Restarting”, it didn’t really come on until I power cycled it.
