I’ve been using volumio for a while on a third generation pi. However I’ve come across some smart plugs that need Domoticz. Is it possible to run this next to volumio on the pi?
Everything is possible if you have the right motivation and resources
Is it recommended? - no, unless you are willing to debug and fix things yourself
Haha quite curious which issues might arise…
Is someone succeeded to install Domoticz on Volumio image?
I am interested…
You can install Domoticz along Volumio on the Volumio image, but it will be a complicated task.
Domoticz requires older packages, which are not available anymore.
So you need to google the heck out of it, to find older libraries (deb) or even compile them from source. (ssl1, libcrypt1,…)
IMHO, I wouldn’t advise it as it will not benefit Volumio.
Thanks for your feedback.
I have only briefly tried, but reverted to just using a second PI…
