I have done a search for this but can’t see anyone else having the same issue.
I set my volumio to update to 3.576 and the wifi card is now not recognised at all(was fine before).
Wifi dongle is RTL8811 chipset, is this being removed from future builds? Any way to add it back in? I have checked the card and its working fine in windows so not a hardware issue.
Thank you for your answer, i was aware it was a test build was just concerned WiFi support four my NIC was going to be removed. I have rolled back and hopefully the next release will still have my drivers.
