RPi5 memory usage - a question
Just done a clean install of v4.231 on RPi5 4GB and system info plugin shows 99% memory usage.
Is this normal
Is it a problem?
If so, can I improve things?
System works fine with Topping E30 II DAC and sounds great, so should I ignore the 99% memory usage?
ok, after another reboot system memory uase is now 32% - which looks bmuch better.
The system is very busy for quite some time after a clean install - expanding the filesystem, etc. Without CPU hungry plugins it should return to around 1% on a Pi5 4GB when idle.
Hey @Bigguy2018,
