Rpi5 display error
HI GUYS
Have RPI5 and i can not install TOUCH DISPLAY always says error
have 64gb micro sd put display in display 0, try it over my 7" display , big tv screen , monitor , old version of volumio Volumio-3.779-2024-11-08-pi and try it new version Volumio-3.832-2025-07-26-pi but it s always the same lease what is wrong , with RPI4 i dont have this problem
thx
What kind of display are you using, HDMI, I assume?
It’s hard to troubleshoot without knowing the exact error, so could you share the message you’re seeing?
If you want to stay on V3, make sure you update to the latest release (V3.886), which fixes the Buster repository issue.
However, keep in mind that Volumio has already moved to V4, and V3 will reach end‑of‑support soon.
thx , i used 7’’ touch display waveshare , i solved the problem , i install Volumio-4.073-2025-12-05-pi and RPI imager, now its work
