Hi All , I am using a rpi 400 connected via usb to an smsl D6 DAC ,
i am curious if using a 12S DAC will give better results ?
I am willing to try but as the rpi is 400 model i understand that only the DacBerry 400 s or m will fit directly
to the rpi
i will be glad to know your advice
to know if the DacBerry 400 is supported by volumio
and DacBerry HiRes quality vs other options
thank you all
