RPi4 with Allo DigiOne stopped working, not on network
In recent months, my RPi4 with an Allo DigiOne SPDIF hat stopped working; now it doesn’t even show up on my network, and the Volumio temporary hotspot doesn’t show up as a network option either.
I had a similar problem two years ago but reflashing Volumio fixed it. This time I’ve tried downloading Volumio from Volumio.com and flashing it via Raspberry Pi imager and Balena Etcher and neither option worked. Any possible fixes? I can get it to show up on Moode so I think it’s a Volumio issue. Thanks!
I suspect it must be another problem.
I have been running Volumio with DigiOne and also with DigiOne Signature for a long time without any problems.
Have you checked the power supply, is it sufficiently dimensioned?
Connect it to the router with a network cable (Ethernet) and check whether it then works.
Thanks rost21A! I wound up getting Moode to work so I’m just going to go with that.
