RPi3+Kali reclocker+Piano DAC 2.1 only plays 16/44
any flac trac with a different bitstream comes across as noise.
Also, any web radio is also noise. For example any of the popular stations like KQED, just hissing noise.
Running the latest volumio.
Here is some info on my setup:
permitted by applicable law.
volumio@volumio:~$ aplay -l
Subdevices: 4/4
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 IEC958/HDMI [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 0: ALSA [bcm2835 ALSA], device 2: bcm2835 IEC958/HDMI1 [bcm2835 IEC958/HDMI1]
Subdevices: 1/1
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 3/3
card 2: PianoDACPlus [PianoDACPlus], device 0: PianoDACPlus multicodec-0 [PianoDACPlus multicodec-0]
Subdevices: 1/1
volumio@volumio:~$ cat /boot/config.txt
initramfs volumio.initrd
gpu_mem=32
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_force_hotplug=1
include userconfig.txt
Volumio i2s setting below: do not alter
dtoverlay=allo-piano-dac-plus-pcm512x-audio
