Really hope someone can point me in the right direction.
I have a RPi 2 with an IQaudiO DAC+ running Volumio 1.55, all connected through high quality interconnects to a good amp and decent speakers. I have tried playing mp3 and flac of varying quality and the sound is just not nice! I get better audio quality playing the same tracks through a 3.5mm jack from my phone.
At first i thought it was the power supply. I have since tried several including a battery to no avail. I have tried Volumio downloaded from here, and the version provided by IQaudiO. Iāve checked all of the various settings i can find on the forum. sudo aplay -l displays the board. /etc/modules has all of the right ones listed. alsamixer settings look correct.
Iām really not sure what is going on. To describe the sound, its like it loses all clarity, high notes especially vocals become distorted and buzzy. Everything starts to merge with no depth to the sound. At first i thought it was just me, but I had a friend over the other day with no interest in hifi and he even asked if I was playing a particularly low quality file without being prompted.
Iām about to flash Volumio again in case i have been unlucky with two bad flashes. But any help would be appreciated, Iām getting to the point of sending the board back.
Hi!
Is it your first config with this DAC or have you ever used it properly ?
Have you choose iqaudio dac plus in the webUI ?
i own this DAC and it is good sounding. Maybe a hardware problem ?
I have it as aux on a stereo set to 80/82 in the webui. Set the stereo to a volume that is easy to listen to, now I can increase and decrease the volume from the webui if I want. 80 leaves some head room in both directions.
When I need to reset my pi I use a headphone to check if it is working properly. Then 80 is hurting and below 16 starts to become muted. I never really used it with headphones for long. (steelseries 5hv2)
The volume level that should be set as a max will depend on the linux kernel version being used AND will also depend on software or hardware volume settings within Volumio. The whole thing is also confused due to the linear and logarithmic volume control difference between ALSA and MPD.
Weāve had 0.1% failure rate on Pi-DAC+, itās a reliable board but obviously happy to swap out any defective board that ever presents itself.
Iād also suggest looking at some of the other audio distributions out there and doing a comparison, soon there will be RoonLabās RoonReady support with native Tidal streaming too.
So I dismantled the whole thing, popped it back together, reloaded volumio and I changed the ALSA volume settings as per the iqaudio manual. Sounding great now, so god knows what happened during my initial installation.
One point though, now I have changed the settings in ALSA the volume dial in volumio sits at 0 and i have lost the ability to change the volume from the UI, any ideas? Itās not a huge issue, just means getting off my arse to turn the knob on the amp instead.
I have the same seutp, a pi2 with iqaudio pi-dac+. Have you tried to set the volume arround 80%? I have experienced distortions if the volume set of the iquadio is between 100-80%. Setting it in 80 solved the problem.
That whole story is interesting.
It will be very precious to avoid this kind of situation in Volumio2, by allowing to select the proper volume control and setting max a min levels as manufacturer suggestion
Solved the volume problem, my mpd config was incorrect.
When you āSave Changesā after setting the Mixer Type, it sets the mixer_control in mpd.conf to āDSP Programā, it needs to be āDigitalā to match ALSA.
[code]audio_output {
type "alsa"
name "Output"
device "hw:0,0"
mixer_control "Digital"
mixer_device "hw:0"
mixer_index "0"
dop "no"
I had the same problem (via DAC+'s headphone amp, distortion with higher volume level), sshād into everything, burned sd card repeatedly, disassembled it and put back together again⦠And I just put the headphone jack half-way in. I found out when I tried another headphones that came with mic and longer jack ā I put the box on its side and pushed hard as I knew that jack needed it. Of course that ānormalā one needed it too.
I share this so that others doubt a little more before working through all the aforementioned steps
